P1000 Issue with the (ROPS)
L
lotches59
9
11
quebec
Hello everybodys ,
Did you have seen that before ? my sxs is an 2018 and just saw today
7DCA586B 2FB4 4685 85D0 8BB7977776BC EF6DDFFC 7CCE 4B71 AA76 48C8FDD10B15
63,543
Haven't seen yours.. But I have seen serval others.
What are your questions?
If you asking about the alignment being off.
That is acceptable and nowhere close to being considered "off".
New or used.
If you need it to be aligned, you need to loosen all the other ROPS bolts so you can more easily force it around.
Honestly, that little bit can be manhandled in with proper tools.
63,543
OR...
Are you saying it was missing the bolts?
That might be the dealer.
Being from Canada...
I guarantee it was shipped knocked down on a metal creat.
Reactions: Lady01
L
lotches59
9
11
quebec
I plan to rim the holes and fill them with
the right graded bolts
  • Wow
Reactions: Lady01
Robobrainiac
Robobrainiac
2,458
8,558
Why would you ream the holes out?
You are way overthinking the solution.
It can easily be persuaded enough to get a bolt in.
And if you cant. Loosen the other ROPS connection points and do it right.
There must be an overstock hidden somewhere. Red comes off the assembly line so fast it stacks up and waits around for the other colors.
Reactions: Lady01
Robobrainiac
Robobrainiac
2,458
8,558
I would have been to tractor supply already and had some grade 8 bolts sold cheap by the pound in them holes....
Hondasxs has it all figured out for you.
