they finally released the new launch mode for the 19 and 20. and now support the 21. just updated mine. worked fine. launch mode works. had a issue relearning the clutch. after a successful relearn it shut off engine when ever i put it in gear and would not restart until its in park. did a relearn again and now its fine. i have been told it is a finicky process and some times it fails.
how many of you do a relearn once and a while? i have noticed after a few hundred miles of beating on it, the clutch engages later(almost feels like a worn belt engaging), i do a relearn and it is then fine. thoughts?
