P1000 junk tires.
Marshallmike25
Marshallmike25
25
44
California
Tires and wheels came today. This is what this machine should have looked like from the factory! Wayyyy better!
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
I run 8.5lbs in my 30s. Good ride and grips well.
What pressure are you guys running in your 28" evo's?
Depending on how fast you ride and the load in the vehicle will determine what pressure. I typically ride a little slower most of the time with a burst of speed occasionally. If riding alone, I would run around 7-8 psi. If you have passengers, you may need to increase pressure to 9-10 psi. Also if you ride fast, you may want more pressure so you don't pinch a sidewall.
In short, I adjust pressure for the terrain. Later today I will be riding slow in a rocky terrain with no passengers. I have set my pressure to 7 psi. Next week, I may have my family, coolers, etc. so I'll set pressure 9-10.
