P700 KFI Plow Mount
Harman24630
Harman24630
283
493
Tazewell Va
Is there any difference in the mounting plate as far as year to year? My 700 is a 2016. eBay has list one for 2014-2015 and one for 2016+. The reason for my question is that the 14-15 is a little cheaper.
swsebek
swsebek
2,854
5,835
pa
I do not believe there is any difference on the plate.2014-2018.Just go to there website like I did.Ebay listing may be older or they just didn't give all the info.
swsebek
swsebek
2,854
5,835
pa
Harman24630
Harman24630
283
493
Tazewell Va
I have a winch mount me and my friend made but I'm fixin to pull the trigger on a snow plow gonna go with the 66" KFI. Like I said the 14-15 kit is around $30 cheaper not a big difference in price just looking at getting a wireless winch remote under budget. At the same time I don't want to cause myself any useless problems by not ordering the rite one to save $30.
swsebek
swsebek
2,854
5,835
pa
Just my 2 cents but if you plan on getting bigger tires later, The 66inch at full angle leaves 3 inch packed snow on both sides cause the blade only plows 60 inch wide. I recommend 72 inch.
Harman24630
Harman24630
283
493
Tazewell Va
2 cents accepted I've went back and fourth with that too... where I live it's paved uphill backroad that the state refuses to plow and a gravel driveway. I had a 1978 longbed chevy with a western cable plow but life happens and I sold it. I know it's big shoes to fill but I'll b using it to plow my road and keep my driveway ironed out from heavy rain washouts. That all said I was looking at the 66" to possibly being less stress on the pioneer but at the same time it'll have to do more work to make up for the 6"... Go big or go home is a good rule of thumb tho.
Harman24630
Harman24630
283
493
Tazewell Va
Looked on the KFI website and list the same plate part # from 11'-18'. Also I ordered my new 72" plow kit should b here around Wednesday.
Reactions: swsebek
allgm1
allgm1
1,049
1,485
New Hampshire
You'll be happy you went with the 72" especially if you have a lot of ground to cover, the 700 is a beast, I wouldn't worry about stressing it plowing snow.
Reactions: Harman24630
Harman24630
Harman24630
283
493
Tazewell Va
Got it!!! Now I gotta wire up my winch solenoid and wireless control(4500# tractor supply winch only came with manual buttons)
IMG 1019 IMG 1020
Reactions: swsebek
xltman
xltman
188
369
US
Is it just the pictures, but it seems to stick way out. Was looking at the same plow.
Harman24630
Harman24630
283
493
Tazewell Va
It sticks out pretty far from the outside looking in but from the inside if it was closer you couldn't see the plow and once it is angled being 72" wide needs to be out that far. I like it a lot it's built extremely well, I've not had any snow to push but I have pushed gravel around and it turns the pioneer into a rubber tired mini bulldozer so I figure snow will be no contest for it.
