P500 KFI winch mount
hondabob64
hondabob64
215
795
Louisiana
I mounted my winch w/ KFI Mount on my P5. It’s in front of the radiator. Can I mount it upside down where the fairlead us through the front bumper? Don’t mind it guarding the radiator, but would I have more airflow & improved cooling the other way?
JCart
JCart
895
2,020
Kamloops, BC Canada.
Mounted mine on top, never have had a concern with overheating, better protection for radiator too. Guessing you don’t use a plough, for me better mechanical angle higher. Will there be room for fairlead from up side down and getting at winch control? I’m thinking it’ll be tight for up side down and will interfere with stock bumper.
If it works and you’re happy why not!
j
Reactions: Todd627 and trigger
173,932
I have mine mounted up top, which is a better lifting angle for plowing and it does kind of block the radiator. What's funny is I've seen several guys have a problem with plugging their radiator with mud and they all seemed to be the bottom mount type. Don't know if it's coincidence or if having it up top is actually helping to block the mud. As for cooling, mine's never gotten too hot.
Duckhunt
Very, very interesting @trigger. I just got my p5 with bottom mounted winch last summer but the one long dry, muddy ride I went on this was my radiator after 60 miles, and I saw 3 bars on the temp "gauge"!
IMG 06781
Reactions: Mudder and trigger
42,670
I have one of the low mounts. I'd rather have it up high, personally. And the 500 seems to have plenty of reserve as far as cooling.
KYhillbilly
KYhillbilly
550
1,651
Ashland, KY
Factory mount is low I believe, i have KFI mounted high and never had an issue with over heating and it adds protection to radiator. It also keeps it above the water on creek crossings(most of the time)
Reactions: Mudder
Mudder
Mudder
NTC Ambassador of Walls
11,605
87,356
I have a Strongmade bumper and winch on top, never had a problem with airflow. Only one mud clogged radiator from a long group ride. Top mount is also easier if stuck in a mudhole.
9791798C 33A4 4A87 8B63 D46C5EAB17A0
bumperm
bumperm
1,889
6,743
Gardnerville, NV
It may sound counter intuitive, but turbulent air flow (as one would have behind a winch or other object, cools more efficiently than smooth laminar flow. So moving the winch lower would be unlikely to produce better results. Either way, there are other things (like the grill) in front of the radiator. In this case, not worth worrying about, so long as the radiator is not shielded from the flow.
