I purchased the Kolpin 98315 on Amazon for $40.89. The mirrors are really nice but the mounts are a little larger than the Honda Roll Bar so they will require some modification.
You will need a piece of black rubber hose and cut it to the size and length of the gasket that came with the mirrors. Do not use the gasket that came with the mirrors. I got the rubber hose from home depot for $5.00. So for $45.89 fthese are half the cost of the factory Honda mirrors. They work great and look real nice on the trail if you hit something fold in. Be sure to tighten all the nuts under the mirror as well once everything is adjusted. No vibration whatsoever.
