P1000m5 LE Heat sheild install
You need to install a 10 inch fan ceramic coat headers and pipes along with heat shield and heat wraps that 4 inch bilge pump fan will not last cannot be used extended time frame bearing melts case also if your in desert dust will destroy must have sealed bearings have fixed problem Email me at [email protected] for photos
Thanks.. I've already swapped my bilge for an 8" rad fan. And have a heat shield. But a lot of the guys are still running the bilge blowers with no troubles.
F
fireman377
I installed 4 of them and they all failed from the sand or the heat I live in the extreme az the new sealed fan is now 1 year old and have driven 6000 miles
Reactions: JTW
