LED for stock headlight
240tt
20
Does anyone know if there is a LED direct swap bulb for the Pioneer '15 Pioneer 700. Stock headlights are a little dim and if can just do a swap would be fine for me. Did think of maybe a small light bar in that 12" range to mount on top of front bumper but then need to run wire harness with relay, fuse and switch. I like to keep things clean.
You could probably run a 12" bar off the headlamp circuit. It's in the 70 watt range and the headlamps are in the 35 watt range. I don't use my headlights anymore, I have a 12" and 24" light bar.
W
Westtnpioneer
Edjumacated
350
603
West Tennessee
ddmtuning.com has plug and play hid kits. I have used their kits in all my vehicles with zero complaints.
Beacheagle70
Beacheagle70
Put two spots and a light bar on the front bumper, easily adjustable and really lights up the world.
Reactions: sxs2015 and GSPKurt
raycox4385
raycox4385
12
7
I'M GOT THESE IN MY 700.
OPT7 FluxBeam 881 LED Headlight Kit w/Clear Lens-Beam Bulbs - 60w 5,000Lm 6K Cool White CREE - 2 Yr Warranty
HondaTech
Shame the Honda LED headlights that fit the 2017 and up P700 wont fit the '16 and older models.
I think the only difference is the grille/headlight surround and buckets.
