P500 LED front marker lights
rocmar
rocmar
4,741
5,776
4 CORNERS
Eagle Eye 1" Alloy white light
remove plastic rivets (2) holding
light housing together....ream
out another 1/8 "
Insert light in its place...
secure with nut...wire
to headlights. ..WALLA
I like um.
20160811 135015 20160811 135002
Reactions: Jshell3
rocmar
rocmar
4,741
5,776
4 CORNERS
Tonite Will post pic
of the amount of light
these things throw out
rocmar
rocmar
4,741
5,776
4 CORNERS
Top one shines up & out......to the side...
Bottom one shines down & out.....to the side
by looking at contour of plastic housing
for headlight you can see direction
They look better than rivets...
& seem to be protected by
bumper....
20160811 144740 20160811 144706 20160811 144632
Jshell3
Did you come up with this on your own? That's really cool... Will copy!!! (I don't even care if they throw out much light.) You've been LED Busy!
Reactions: rocmar
rocmar
rocmar
4,741
5,776
4 CORNERS
No...
this is my deal
on tight rock trails
I need to see..where my tires
are..I'm not sure..if the position
there in...is gonna work...
but will see tonight....
plus...looks kool...
rocmar
rocmar
4,741
5,776
4 CORNERS
Switched porch light
is a kool thing...to
rocmar
rocmar
4,741
5,776
4 CORNERS
Get the Alloy ones....Bout
$5 each....
plastic ones cheesy....
only 3w.....
not 9w
has 12" leads
41BWaP9NfvL SY400
rocmar
rocmar
4,741
5,776
4 CORNERS
Kool....share it...
That's wat this forum. ..
is all about..
rocmar
rocmar
4,741
5,776
4 CORNERS
If ya got a 10 pak
for $14...
that's the cheap ones
don't last...goes dull
fast..
rocmar
rocmar
4,741
5,776
4 CORNERS
Not as close to tire
as I was hoping. ..
It does give some
side lighting
20160811 201001
ehart814
ehart814
1,653
3,631
NWPA
Really cool idea @rocmar !!
Reactions: rocmar
O
oldfortyfive
606
1,371
Illinois
Please post a link to the good ones. Thanks
Reactions: Jshell3
Gator
Gator
The Most Unknown Member
2,488
10,464
Louisiana
I put some of these on a trailer (the come in red and amber also). I've thought about them ever since, but didn't think about exchanging the rivets.
I'll do it.
rocmar
rocmar
4,741
5,776
4 CORNERS
I'll do it.
Do it Gator
Post pics
Gator
Gator
2,488
10,464
Louisiana
Get the 3w
not 9w.....
cheap ones ....reviews weren't
Good....
Amazon.com. ..... eagle eye LED lighting
Why 3W instead of 9W?
Is it just that you haven't found the quality in 9W?
I searched all over Amazon and didn't see the ones you pictured.
rocmar
rocmar
4,741
5,776
4 CORNERS
No....
I'm running one battery
low voltage. ..
like the 3w....
the 9w....little intense
you may like um....
I know the cheap ones
are all plastic
