P500 LED Lightbar Question
MidTN
31
86
Middle Tennessee
I'm looking at the 12 inch Tusk LED lightbar kit. It looks like that model pulls 74 watts/6 amps. If that is correct since it is drawing less than 10 amps is it safe to run plug this directly into the Honda sub harness I installed when I added my winch? Is there anything else I need to be aware of if I try to install this myself. I'd really prefer the simplicity of using my accessory sub harness if practical. Any tips would be greatly appreciated...
NitroxDiver
NitroxDiver
488
918
Concord NC
You could probably get by with going straight to the connector but I prefer to use a relay. If you add anything more to that circuit as most people do you will be over loaded.
Reactions: trigger
