Code54 Well-Known Member Lifetime Member Club Contributor Jan 31, 2015 585 635 93 Hurricane West Virginia Ownership Other BrandTalon X Jun 19, 2015 #21 Watch that your switch is not your weak point - that is where the relay comes in, to allow for a smaller switch. Reactions: ohanacreek and jak9922
jak9922 hot headed wopolock Vendor Lifetime Member Jun 2, 2015 3,283 5,636 113 pittstown ny Jun 19, 2015 #22 Absolutely code54 check the rating on both
jak9922 hot headed wopolock Vendor Lifetime Member Jun 2, 2015 3,283 5,636 113 pittstown ny Jun 19, 2015 #23 I like to run 20amp rockers and try and skip the relay but sometime ya just cant
joey400ex Member Mar 18, 2015 49 31 18 Jun 22, 2015 #24 I am running a 25amp rocker switch, seems to be working fine at this point, I will keep y'all posted. Thanks, again.
jak9922 hot headed wopolock Vendor Lifetime Member Jun 2, 2015 3,283 5,636 113 pittstown ny Jun 22, 2015 #25 nice good job!!! also it wont hurt to when ur using the light for an extended period just feel the switch and wire to make sure they arnt heating up at all
joey400ex Member Mar 18, 2015 49 31 18 Jul 15, 2015 #26 FYI, the light is working just fine. The larger gauge wire did the trick. I have ran it over 10 hours with no issues.
jak9922 hot headed wopolock Vendor Lifetime Member Jun 2, 2015 3,283 5,636 113 pittstown ny Jul 15, 2015 #27
