P500 left key on, ran battery down
GRANITE
GRANITE
People Dying to come see me!
1,132
5,784
Brookville, Indiana
Well, I never thought I'd do it but it happened last night. Somehow left the key on and and ran battery dead. My first service wrench now comes on and I think it has 41 miles on bike. anyway to fix the computer so its back to before the key was left on?
NTCPrezJB
NTCPrezJB
Retiring Member
113,000
976,657
Hidden
I assume you were able to start it (via jump or battery charger) and revive the battery? If so, I'd guess you could just do the maintenance reset (forget which button you have to hold down) and then just don't forget you still have to do your 100 mile service and do the reset again when that time comes.
67,230
Nope.
Best thing to do is leave it on until the first service at 100 miles. Then reset it so it starts correctly for the second service.
GRANITE
GRANITE
1,132
5,784
Brookville, Indiana
I keep one of those Lithium Ion battery packs that are small to jump a car battery. I hooked it up and it got it started again and left it run to build the battery back up.
NTCPrezJB
NTCPrezJB
Retiring Member
113,000
976,657
Hidden
I change my vehicles oil based on the odometer, so my Toyota minivan is every 10k miles. I've had intervals go a little long at times like pushing an extra 800-1k miles even and I've never had an issue resetting the maintenance interval "early" next time around. I've not done it on the P500, but I've done maintenance this way with several different street vehicles from multiple manufacturers and never had it not work. I'd honestly be shocked if I couldn't go reset the P500 right now even though it is only 20% maybe through its cycle.
67,230
Sure. You can reset it if you like.
But remember there are 2 modes. So double reset will be needed to get it back to clocking on wrench 1 when you really do the oil change.
Or, if you check everything every time like some people. Then it really does not matter which wrench is showing.
natewheeldrive
natewheeldrive
Pittsburgh, PA
I did an early oil change st 480 miles because I knew I would be over after a 4 day trip to the HMT. I hit 600 on the odo and reset it by holding the button down on the display and turning the key to ON, let go when the wrench disappears. Chime in if im wrong but I believe your hour meter is the issue. The computer clocks hours by key on time not engine run time. Your hours of operation will be skewed for the life of the machine.
Reactions: GRANITE
GRANITE
GRANITE
1,132
5,784
Brookville, Indiana
Its no biggie though. But yes the hours show 12 more than it should...Merry Christmas
