P700 Less aggressive all-around tire?
L2R
L2R
Understanding women Vol. 1
1,063
6,599
East of the Appalachians
UPDATE:
Went for a little more of a test ride yesterday and this thing rides EXTREMELY ROUGH now.
Gonna soften the rear up a notch and air down to 10psi and test again .
thanks for the update. I am considering a tire change and interested in what you are learning. Hope the reduced psi works for you.
Guitaraustin99
Guitaraustin99
26
53
West Virginia
I aired them down today and took notch out of the shocks and it rides better than it ever has. Also, West Virginia red clay mud is no match for these tires.
mjn
mjn
1,409
5,206
SE Washington State/N Idaho
What is the height of those tires once mounted & aired up?
did you by chance weigh them before you put em on? Just curious... the tread pattern on the BFG is pretty similar to the Terrabites, just wondering what the weight difference is.
The 28X10X14 Terrabites weigh 33 lbs.
Alan_Vander
Alan_Vander
1,547
2,752
rosepine,la
all around tires id id h to say the big horn 2.0s in a 27 or 28 would be about max. depending on the trails you ride. if off camber trails you want to ride with something like a zilla. type tire where the tread is more of an inline. if not worried about sliding sideways god with a kenda executioner
heavy tire. 27 is all the bike wants but its a goat with these tires. and if your snorkeled 12 psi all around and it water wheelies just a little past the dash
Reactions: Backwoods
Dave_H
Dave_H
22
40
Here is what 27” Sedona Coyotes look like in stock rims with a Strongmade 2.5” lift. Very happy 200 miles into this setup, much less road noise on hardpack and pavement. MUCH easier on turf than stock setup. Don’t forget to do an alignment after install, mine was 1” out from the stealership.
B48458A1 D47A 44BB A09E 7394455B4551
Reactions: Mudwing and L2R
Guitaraustin99
Guitaraustin99
26
53
West Virginia
I didn’t weight them but I’d say they’re close to that. I’ve put over 400 miles on them since and the front front will occasionally rub the back of the fender well but not enough to hurt anything.
