They must have some bite!
They amaze me how well they get around and yet they are so smooth on the road. 2" tall treadThey must have some bite!
Anyone out there runnin em?
That looks really good! I wonder if those would clear on a stocker if you trimmed the frameWouldn't exactly call them skinny's but... 28x10x12 BH 2.0's on ITP Black Ops 5+2's. 1" spacers on rear to even track width. Forward arched A arms so no rub.
View attachment 328656View attachment 328657View attachment 328658
That’s one of the nicest p500 I’ve ever seen! Good job👏Wouldn't exactly call them skinny's but... 28x10x12 BH 2.0's on ITP Black Ops 5+2's. 1" spacers on rear to even track width. Forward arched A arms so no rub.
Was thinking the interforces or intimidators but not sure how they would be on hard packBunch of pics of 30" Interforces in older threads on various rims. Big fan of 4 fronts with 'pizza cutters'. You have to get 2" or even 2 1/2" rear spacers. Another variation of the flatfender look would be any of the ITP rims that come in 14x6's and scrawny 9's (Zillas,ML2s) or even some 10s.......
Will it float?Wouldn't exactly call them skinny's but... 28x10x12 BH 2.0's on ITP Black Ops 5+2's. 1" spacers on rear to even track width. Forward arched A arms so no rub.
Well since my bear claws got back ordered… Trigger has inspired me to go with 28 x 10 x 12 big horn 2.0 on all four corners… I might as well go out and grind that piece of frame off on an angle right now lol
I’ll deal with it…around here everyone is running 28-32’s on the bigger buggy’s…I’ll deal with the rub to not be high and dry in the ruts…been modifying cars/bikes/buggy’s since I was I kidIt's not just the frame that's the problem, it's the fender well by the cab too. I rubbed there with 26x11's on 5+2's and 1" spacers. Keep in mind the BH's run true if not bigger. I measured mine at 28 1/8" when I first got them. Some don't mind it but without new arms my guess is you'll rub somewhere.
Hopefully SuperATV finds out soon if his arms will fit!It's not just the frame that's the problem, it's the fender well by the cab too. I rubbed there with 26x11's on 5+2's and 1" spacers. Keep in mind the BH's run true if not bigger. I measured mine at 28 1/8" when I first got them. Some don't mind it but without new arms my guess is you'll rub somewhere.
I mounted SUNF 27x9’s on all four corners on mine. They rubbed on the frame until I air’d down to about 6 lbs. I added 1” spacers, which moved the tire away from the frame, but now they “barely”rub the fender. Best fit and ride seems to be around 10 lbs. I should be okay once the tires wear about an 1/8”. In retrospect, I should have only gone up to 26”.View attachment 330707View attachment 330708
Nice! What wheel are you running? Where did you get them? I’m going to need some soon.I mounted SUNF 27x9’s on all four corners on mine. They rubbed on the frame until I air’d down to about 6 lbs. I added 1” spacers, which moved the tire away from the frame, but now they “barely”rub the fender. Best fit and ride seems to be around 10 lbs. I should be okay once the tires wear about an 1/8”. In retrospect, I should have only gone up to 26”.View attachment 330707View attachment 330708
