P1000 License Plate Location
Up2It
Up2It
Calgary Alberta
We finally registered our new machine,(still working on a name), and now I have a License plate that I have to install somewhere on it. Normally this is a no brainer, but I haven't seen a single picture of a machine that has a plate, or a location that looks like it was made for one...any suggestions from those that need to run a plate?
Jody
Jody
31
Manitoba
I mounted mine to the exhaust cover. Nice section in the center that seems to fit the plate nicely. Pulled off the cover, riveted plate on and bolted back up. Pulled the spark arrestor out at the same time.......
Reactions: Stauvo
Up2It
Up2It
Calgary Alberta
I just looked and that makes a lot of sense. Is there a specific reason you used rivets rather than bolts? I have to get together whatever I am going to use take it to the cabin when I go..so I wanted to make sure...
Stauvo
Stauvo
633
910
Minnesota
Hey there you two, welcome to the club.
That sounds like a good place for a plate.
Jody. Was the spark arrestor easy to remove? On my Foreman its 3 bolts pull out and used a cutoff wheel on the screen.
franzw
franzw
277
249
pacific nothwest
Here is where mine ended up, kind of interfered with the trailer hitch so I added an extension, much better now :)
100 0940
Bornlzr
41
35
How big are the plates in Canada? I just mounted mine last night to the center of the tailgate using jack nuts and 1/4" bolts. The license plate measures 5 x 8 and ordered it from Lone Rock Trophy who has Wisconsin, Minnesota and generic plates, great service!
IMG 0061 IMG 0062
