P500 Light bar location
212,709
Had never thought about that? How are of a job is it?
Strap the steering wheel straight, measure the back side and front side of the tire lines, adjust both side equally (tie rods)until you have the toe in (front you desire) I run an 1/8 inch toe in, this is the quickie method. Example front measures 60 & the rear of the tire measures 60 & 1/8, be close to 1/8 of an inch toe in in the front. Be careful, most stock alignments are set with a big toe out in the front to keep people from flopping but wear badly on pavement. Chime in guys.
Reactions: THeck
PJ1
PJ1
FIREBALL P-500
1,289
13,907
Massachusetts
Do you have a shot of that from closer. How about a link to the light? Thanks
The light was purchased off Amazon from Arsenal off road. Not sure of the size off hand. Curved bar. Drilled holes in plastic roof to mount.
20200725 143717
Looks good, thanks for the photo and the info...😊
Reactions: PJ1
PJ1
PJ1
FIREBALL P-500
1,289
13,907
Massachusetts
I'm very happy with this lightbar setup, but do have some vibration which gives the light bar a sort of strobe effect. It's not too noticeable from the driver seat, but is when looking at it dismounted which I decided I like.
