P1000 Light er up
Vikes79
Vikes79
SKOL!
10,913
105,879
South Dakota
  2. Talon X4 LV
I own a 2020 3 seater 1k , Where can i get some nice aftermarket headlights that work better then the stock ones ? Maybe smoked ?
Let me know and safe ridin .
If you have a base model with halogen bulbs, these work pretty good
Check this out!
https://www.amazon.com/dp/B08R3GTFNH?tag=sxsweb24-20
Then if you want more light you can get the high beam splice kit and front bumper light bar from the site store.
Vikes79
Vikes79
SKOL!
10,913
105,879
South Dakota
  2. Talon X4 LV
awesome info . Thank you
Here’s what they look like on my 18. The small light bar is using the club store splice. All my other lights run on my aux battery.
07C62E12 D07A 437A 829B 339AD75F7046
bumperm
bumperm
1,849
6,648
Gardnerville, NV
All else being equal, i.e. same light source, a smoked lens will cut down on the light emitted compared to a clear lens. But for some, good looking is more important than looking good. If it's lighting up the countryside ahead of you that you are after, it's hard to beat a good light bar. My 21 SE came with LED headlights, they work reasonably well, but nothing compared to the Nilight light bar . . . so bright it might start forest fires:
20211017 112959
fernandw
fernandw
24
134
SE LA
The aftermarket LED headlight bulbs @czajkaej references here are a game changer on the stock '22 buggy to replace halogens. I did the swap this weekend on a 22 Forest Edition.
I also have a 13" single row LED bar wired to the high beam switch off the club store on the bumper. The bar, plus the bulb replacement, is more than adequate for trail riding at night in tight woods to/from the stand on known paths.
PXL 20230120 112212059 PXL 20230120 192848543
Prntckt
Prntckt
1,048
7,222
Altoona, WI
I installed the LED conversion bulbs to replace the OEM halogen bulbs, and there was a huge difference light output. Like Vikes79 said, if you need more light than that, the high beam conversion kit and light bar from the club store is a good choice
207,988
View attachment 371102 View attachment 371103
Is your tie rod bent bad?
Reactions: Plowboy1466
fernandw
fernandw
24
134
SE LA
Nope, just looks bad in this pic for some reason.
I'm going to be doing an alignment and toeing it in a bit when I get it back to the house after hunting season.
