P1000 Light Truck Tires???
pct
pct
Lost in the hills
790
1,023
Letart WV
Thanks for the info going to check them
pct
pct
Lost in the hills
790
1,023
Letart WV
I have ordered from them before and got a free t shirt HaHa
Reactions: ChadD
CarneyRacing
CarneyRacing
27
26
I haven't heard many responses from people that have mounted up pickup tires. I know there are at least a couple that have done it, what are your thoughts? What size tire did you buy? How does the machine ride and handle with the pickup tires? I don't plan on lifting my P1000-5 at all, so I'd potentially be looking at 215/75 R15 to stay fairly close to stock diameter, but I'd like to hear what others have tried.
Tot
Tot
661
462
Des Arc, Arkansas
I'm ordering them today so when they get in and get some time on them I'll report back
Reactions: ChadD and dale5740
Tot
Tot
661
462
Des Arc, Arkansas
I wanted the Federal tires, but Amazon only had 1 in stock. So I bought some Nankang M/Ts from Discount Tire Direct for under $424. 3-7 days on shipping
dale5740
dale5740
886
417
mt airy md
so how much weight will u guys be adding per tire assuming u are doing stock size equivalent
Reactions: ChadD
Tot
Tot
661
462
Des Arc, Arkansas
E27b15b3b51ee9b72c70ba3d23556948
3dee84e8e175839e3e6da90f749bbf11
5a64b1e64beba781ca1d5440829fc6d1
1e85bb4c42168b6f1c9f4338962dd07c
Same bucket from the other pictures after the lift.
F81cdf982e0e1d3bd78a26753723b791
Dc842c0740c2d146e2f699c72b0df886
Side shots:
B8eafa05c5fe2943eaff39b51f495cc2
20f2d9698fa02d64ab451950a6861c5c
77d40565e77c0cb93bed25263b603ea1
Tot
Tot
661
462
Des Arc, Arkansas
Got my tires in today and mounted up! Liking them so far drove them down the road and back so far. I'm going to ride tomorrow and get a better feel of them.
Mounted right now the tires measure 28" (I'll check again them in the morning)
Gained another inch or so off the tires.
Front by the door: just under 16 inches
Rear ( by the step thingy at the back of the cab: 17 3/4"
Reactions: pct
CarneyRacing
CarneyRacing
27
26
Can you get a couple pictures from the side? How much were the tires?
Tot
Tot
661
462
Des Arc, Arkansas
I'll get some in the morning.
They were $423.88 with valve stems. With out would save you $12. Which I did not need because the wheels came with them and didn't know it.
Reactions: pct
dale5740
dale5740
886
417
mt airy md
I was going to order Federal Cougaria off Amazon but they only had 1 in stock when I was puchasing. I found those tires on Discount Tire Direct. They are 235/75r15
I bet those ride like a million bucks. Im thinking about doing something like this in summer and winter when plowing putting stock tires back on with flush mount spikes that wear down with tire. I just don't know if this is an aggressive enough tire for me or not. I think I would like something like big mud terrains in summer and bighorns with spikes in winter (spikes isn't the word Im looking for but Im tired can't think)
Tot
Tot
661
462
Des Arc, Arkansas
I think you're looking for the word "studs"
What kind of terrain are you going to be riding in?
Tot
Tot
661
462
Des Arc, Arkansas
From what I've herd/read they are 4x136, however 4x137 wheels do fit. Just make sure to get 12mm lug nuts or reuse the originals.
Reactions: dotman1
