P700 Lightbar placement with factory roof?
bassadict69
31
20
Benton, La
I believe I know the answer to this, but is the factory roof going to force me to mount the lightbar somwhere besides at the top of the windshield like I see others mounted?
WagginTail
WagginTail
1,656
6,075
SC
I'm not sure but for me the higher up the better
Reactions: swsebek
swsebek
swsebek
2,854
5,835
pa
you will be able to mount it up high
bassadict69
31
20
Benton, La
I am bringing this back up...I had a tenant move out and he left behind a 51 or 52 inch lightbar he had mounted on his truck, so it has some brackets for that rather than the factory mounting brackets.
I have found the brackets they sell for mounting the lightbar down low on the windshield using the factory bolt locations. I would love to mount it high on the windshield...how can I do this with the factory hood that extends out and down a bit?
bassadict69
31
20
Benton, La
I am also needing some of the original L-type brackets that come on the lightbars...where might I find those?
bumperm
bumperm
1,931
6,829
Gardnerville, NV
I made the mounts for my 54" curved light bar, as I didn't much care for the ones I saw on eBay.
I can't argue with @DaddyDubbs, a high mounted light in rain, fog etc. is a non-starter. But, for all other more clear lighting situations, a high mounted light gives better useful range and better perspective. It is more labor intensive to install, though I think for sure worth it.
I did a write-up on the install, posted a couple of years ago. The 1/4 - 20 bolts go into rivet nuts in just one side of the roll cage corner gusset. The ones I saw elsewhere used longer bolts through both sides of that gusset, but I thought the added clamping pressure on the gusset not the best way to go. What I did works well, it's solid, doesn't vibrate, and holds adjustment.
20211017 112959
20210806 122901
Reactions: DaddyDubbs
DaddyDubbs
DaddyDubbs
15,418
145,492
Depending on current draw a relay may not be necessary, but it can't hurt and I like the added electrical protection. If you are not familiar here is a schematic on wiring a relay for lights.
Relay Wire
jbry
jbry
11
Finger Lakes, NY
Thanks guys! I got it mounted down low, just above the hood, at the bottom of the windshield.
Now to figure out the wiring...
@bassadict69 (or anyone else with light bars mounted just below the windshield and not on the roof), can you report out on how they're working for you visually? Lessons learned and what to do/not to do?
I'm just now getting around to outfitting the new rig and we've got a lot of low branches so I'm hesitant to mount a light bar on the factory roof and have it ripped off. And yes, pictures of the build will be posted!
Thanks!
Reactions: Rayger143
116,574
That guy hasnt been on the forum in about a year. Not sure he will see or respond to this FYI
As for your question, yes you can mount it there. People do it alot. No onstruction on my P1. Not sure on a P7 but should be ok. All depends on style you choose and how u mount it
Reactions: Buggyman and jbry
Red500
Red500
6,618
71,078
Greeneville, Tn.
When I got my first light bar I mounted it on the factory roof on my P5. I used some aluminum bars on the underside to distribute the stress and have not had a problem. I've hit plenty of branches without ripping it off yet. Anytime it rains or is dusty or there is any type of particles in the air it would simply light up these particles and make it harder to see. I won a smaller light bar in a drawing and mounted it below eye level and this works much better in those conditions. I now have both and learned that if I want to light up that field, use the upper light, but if I want to see the trail in front of me use the lower light. If I had to choose one or the other I would definitely go for the lower mounting position.
Rayger143
Rayger143
3,373
29,357
Winfield, BC Canada
Thanks!
I have my 50” mounted low windshield and like it there.
1728427681378
1728427716149
Reactions: Backwoods and Coeus
196,693
Been on the forum a long time and I've never seen or heard of anyone doing anything to harm a factory roof.
WagginTail
WagginTail
1,656
6,075
SC
Thanks for the responses guys! I hadn't thought about visibility problems with high mounted lights with dust or fog. Feeling good about my choice to mount under the windshield. Time to do some shopping.
I had a light bar mounted on bottom of windshield on my 700. Liked it so much I did the same on my 1000. For what it's worth... this 24"? (Maybe 22") Traveller light bar from tractor supply is plenty of light. I don't like the ones that go all the way from side to side
20201112 172010
20240210 172137
Reactions: jbry
cloleson
cloleson
14
27
Nederland, TX
I just made an angle iron bracket for mine. I ran it all the way across the front, inside the ROP, and secured it with u-bolts. It's held up so far.
