P1000 Lights in back
BrotherNov
122
281
Springfield, IL
I just purchased a pair of Rigid Pods to mount on the back of my 1000-5. For those of you with a pair of pods on the back, where and how did you mount them?
Reactions: Isaiah
K9Paco
K9Paco
642
2,290
Lake Charles, La
  1. Talon X LV
Tractor Supply
9f70d52c44e7e50d31d000c21a5c7f56
Ecdb7cb2d8bcbb020888c1d5961aca25
I
ImHowl
14
78
Connecticut
I got my plug and play lights from the store here, no splicing wires, two bright lights, comes on automatic when in reverse. Check them out at the @Hondasxs store here
There’s an add on to make it a premium 3-way switch set up. You can turn it on, on in reverse or off completely. It’s a really nice add on. 😎
I have both of these. The lights and 3 position switch from the @Hondasxs store. Works great.
4B38F1C6 F831 4546 8169 20947F74E4AF 1 105 c
770472F9 AD0D 4E5A 876D 7E7E6B85A8FD 1 105 c
RCHondaMan
RCHondaMan
17
47
West Virginia
I tied mine into my front light bar and put a toggle switch to be able to run them separate. The round hole in the frame where the center roll bar goes across is perfect just used a couple big flat washers with 1/4 in hole in middle for the toggle.
B2933332 ACEA 434F 901C C970C9229BFC
5F8C74A7 D312 43BC 9424 1FED5F7A4F77
Roborlilw
Roborlilw
48
68
Tucson,Az
  2. Talon X LV
The pod lights I installed using the backup buzzer pigtail a couple of years ago have recently somehow shorted or something. I replaced the shift position switch because that was the DTC code that came up. While ringing out the new switch I had issues with reverse position showing resistance when it should've showed continuity. Disconnected the backup lights at the backup buzzer pigtail and position switch rang out good. To make a short story long, I would buy good quality light pods.
Reactions: Mudwing
Mopower58
Mopower58
Unburdened by what has been!
81,327
718,218
Crystal Springs,Ms.
Where did you get the "Pioneer" and "Honda" rear guards? Are they available for the 700.
A guy in Kentucky did both. It might take me a minute but I will get you the info. S&S Fabrication,LLC. I saw them on Facebook and I think his name is Shaun. He cut whatever I wanted in them and powder coats whatever color.
1811tactical
1811tactical
39
50
Mississippi
Thanks!
115,818
These are mounted with some clamps I got on amazon. You can use many different types of clamps to your choosing. The lights are Auxbeams. I’ve had them on almost 5yrs and they work great.
1C9A0CDB 02E5 4E05 872A 58E73561E5E0
I used these clamps so you can adjust them to whatever position or angle you would like
1.75'' Custom Side Roll Cage Bull Bar Clamps LED Light Mount Bracket https://www.amazon.com/dp/B075D9CDTC/?tag=sxsweb24-20
Reactions: Mudwing
