I need ideas for switch plate to replace warning label. Really only needing 4 switches. 1 12v outlet, One USB port and 2 volt meter. Really would like to see some pics of yalls builds and what yall came up with! Thanks!
I like that setup. If I end up adding a switch panel I would like that one but with two more circle holes added on the right side in a vertical arrangement in that left over space. Id like to have a volt meter in each of the two you have. And then a 12v plug and USB plug in the two Id like to add to the panel.
The two circle holes are for a volt meter for each battery but now the tru isolator comes with one volt meter with 2 readouts on it so i added a usb to the hole on the right. Also the bottom right square switch hole is a usb as well.
