P1000m5 Limited Edition Switch Plate!
  • Thread starter HunterCollins1996
  • Start date
HunterCollins1996
15
21
Grapeland Texas
I need ideas for switch plate to replace warning label. Really only needing 4 switches. 1 12v outlet, One USB port and 2 volt meter. Really would like to see some pics of yalls builds and what yall came up with! Thanks!
64,756
@mystic1219
Here is a few he offers for the LE. 5c05f42078541026a1f81ccd2ccb463d
HunterCollins1996
15
21
Grapeland Texas
Awesome. Is that a facebook page he has? If so what is it called? I emailed him earlier, waiting for a reply!
Reactions: sharp
HunterCollins1996
15
21
Grapeland Texas
I like that setup. If I end up adding a switch panel I would like that one but with two more circle holes added on the right side in a vertical arrangement in that left over space. Id like to have a volt meter in each of the two you have. And then a 12v plug and USB plug in the two Id like to add to the panel.
Reactions: sharp
sharp
sharp
3,757
14,955
Tennessee
The two circle holes are for a volt meter for each battery but now the tru isolator comes with one volt meter with 2 readouts on it so i added a usb to the hole on the right. Also the bottom right square switch hole is a usb as well.
mystic1219
mystic1219
191
202
Thanks for the tags guys, been on the ball field all evening. I’ve spoke with Hunter over email.
Justin
Reactions: sharp and Mudwing
