P1000 Little nerve racking......
Tuco69
Tuco69
1,474
7,564
Middle Georgia
832CBE85 58EB 49BF 819A B5231783FD65
Know it isn’t much but cutting the area out made me pucker a bit. Now to begin wiring......winch in last week.
BWAF
BWAF
I get paid to pass gas
8,857
42,448
Carthage MO
I was same way 1st hole liked to killed me for as much these things cost but like @GlockMeister said it gets easier
View attachment 86665 Know it isn’t much but cutting the area out made me pucker a bit. Now to begin wiring......winch in last week.
RockRain
RockRain
48
101
UT
Ditto to all of the above. Here is an idea for attaching your switch plate bolts. I just heated them up with a little butane torch and pushed them into the plastic. Makes taking your panel on and off a breeze.
20180913 194559
Download 1
BWAF
BWAF
8,857
42,448
Carthage MO
Good idea would they need to come in from back
View attachment 86850 View attachment 86853
Reactions: sharp and Eltobgi
RockRain
RockRain
48
101
UT
I didn't think about putting them in from the back side. It makes sense to do it that way so it gets tightened in to the the plastic. Gotta love hindsight! However the depth of the nut is too deep for what the plastic is so you would need to grind them down a bit. The plastic is pretty melted around them and so far they haven't moved.
RedFred1
RedFred1
301
619
North Carolina
It's always something, right? They do make different depths but when you get as thin as the plastic is, they might be too thick as you mentioned. It looks like they should hold, as I said, hope it holds for you. I just used self tapping screws and put a dab of clear gorilla glue on the back after I ground off the excess. I hope mine hold too! After all the work I have been doing, I hope to never have to take them off again!
FredD
RockRain
RockRain
48
101
UT
FredD
No doubt! I don't think there is a whole lot of stress on them pulling straight out anyway. I'm sure yours will be fine. With the way mine goes it has had to come off a time or two more than expected to change something.
Reactions: sharp and BWAF
