i could make the mounts for stock or for any shock but looks like i might give the teryx shocks a try they have more travel then the rhinos im using but not a crazy amountAny ideas on shocks?
im hoping to have it done for the take over. and if i was just going to build this for my machine i would definitely remake the mounting points but im hoping to make these kits to sellAwesome buddy, are you bringing it to the takeover?
Also, have you thought about spreading the a-arm mounts farther apart since you’re going longer?
the 700 has different gearing and i dont have the money to buy 1 then change the gearing out to see if it would work then make my kits around that you would just add another 700 to a 1600$ kit alreadyWith a long arm kit, would it be possible to run the front diff of a 700 to take advantage of the locker?
