Thanks much!the 5" is just the max height if you crank your preload and at 62" the stability is absolutely amazing on insane off camber rock and hills it does not want or feel like it going to flop over
Checking with my dealer for installation....Should know more in a day or two.the 5" is just the max height if you crank your preload and at 62" the stability is absolutely amazing on insane off camber rock and hills it does not want or feel like it going to flop over
sounds goodChecking with my dealer for installation....Should know more in a day or two.
Bruce
few companies make forward arms to clear bigger tires for the 1ksGood Morning All - New owner here, I have a 1000-5. Wondering if there is a long travel kit for the 1000? just wondering because i would like to add larger tires.
Look in the Pioneer 1000 section. Super ATV makes arched forward and rear arms that rake the front 1.5" and rear 1.5". You only need to do the fronts if you want to add true 30's. Any more tire than that and you'll want to look into portals or an internal gear reduction. Highlifter and a few others make arched forward arms kits as well, but the SATV is the most popular.Good Morning All - New owner here, I have a 1000-5. Wondering if there is a long travel kit for the 1000? just wondering because i would like to add larger tires.
Thanks all for the help!Look in the Pioneer 1000 section. Super ATV makes arched forward and rear arms that rake the front 1.5" and rear 1.5". You only need to do the fronts if you want to add true 30's. Any more tire than that and you'll want to look into portals or an internal gear reduction. Highlifter and a few others make arched forward arms kits as well, but the SATV is the most popular.
yes but build times are long now because i only work on them on weekends for nowI know this is a older thread but are you still making these kits?
yesI just purchased a P520 a couple weeks ago. Will your P500 kit work on the P520 as well? Thanks!
