BOX1
P500 long travel kit
Bruce4795
112
248
Arizona
the 5" is just the max height if you crank your preload and at 62" the stability is absolutely amazing on insane off camber rock and hills it does not want or feel like it going to flop over
Thanks much!
Reactions: jak9922
Bruce4795
112
248
Arizona
Checking with my dealer for installation....Should know more in a day or two.
Bruce
Bruce4795
112
248
Arizona
Joe, see my post about your kit under Pioneer 500 “Builds”. Thanks again!
Reactions: jak9922
RobMarrison
0
Canonsburg, PA
Good Morning All - New owner here, I have a 1000-5. Wondering if there is a long travel kit for the 1000? just wondering because i would like to add larger tires.
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
few companies make forward arms to clear bigger tires for the 1ks
56,028
Look in the Pioneer 1000 section. Super ATV makes arched forward and rear arms that rake the front 1.5" and rear 1.5". You only need to do the fronts if you want to add true 30's. Any more tire than that and you'll want to look into portals or an internal gear reduction. Highlifter and a few others make arched forward arms kits as well, but the SATV is the most popular.
RobMarrison
0
Canonsburg, PA
Thanks all for the help!
Mbradley42
Mbradley42
2,212
25,746
Waynesville NC
I know this is a older thread but are you still making these kits?
Reactions: Isaiah
Bad Company
Bad Company
49
139
Wartburg, Tn
I just purchased a P520 a couple weeks ago. Will your P500 kit work on the P520 as well? Thanks!
W
Wimerkid
Rogue River
What is your contact information to order your long travel kit?
Reactions: N2u812
BOX2
box3
