P500 long travel kit
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
20190823 164556
Screenshot 20190710 215519 Facebook
Screenshot 20190516 212610 Facebook
Screenshot 20190807 213156 Facebook
Screenshot 20190429 162402 Gallery
Screenshot 20190802 165455 Facebook
Screenshot 20190802 165428 Facebook
Screenshot 20190415 075910 Gallery
im going to offer 2 versions of my long travel kits basic 1100$ shipped - comes with 8 arms longer stainless brakelines and longer tierods full kit 1700$- same as above but with 4 axles and new upper and lower ball joints kits are set up for stock length shocks but you will either need Walker shocks or stiffer springs for your stock shocks
Screenshot 20190710 215519 Facebook Screenshot 20190516 212610 Facebook Screenshot 20190807 213156 Facebook Screenshot 20190429 162402 Gallery Screenshot 20190802 165455 Facebook Screenshot 20190802 165428 Facebook Screenshot 20190415 075910 Gallery View attachment 153606
Chooglin
If you buy the basic kit, what axles need to be bought ?
Russ989
Russ989
22,577
146,638
View attachment 153623 View attachment 153605 View attachment 153607 View attachment 153608 View attachment 153609 View attachment 153610 View attachment 153611 View attachment 153612 im going to offer 2 versions of my long travel kits basic 1100$ shipped - comes with 8 arms longer stainless brakelines and longer tierods full kit 1700$- same as above but with 4 axles and new upper and lower ball joints kits are set up for stock length shocks but you will either need Walker shocks or stiffer springs for your stock shocks
View attachment 153605 View attachment 153607 View attachment 153608 View attachment 153609 View attachment 153610 View attachment 153611 View attachment 153612 View attachment 153606
I wish that was available when I had mine.:cool:
What’s the charge to drop it off at your shop and pick it up installed.....:cool:
Choped5er
Choped5er
182
279
Union
That's awesome. I'd thought about getting a p5 for around the house. How wide does it make it and how much travel is gained?
Reactions: Isaiah and jak9922
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
62" inches wide with the minimum 4x3 rims you need to clear the ball joint plates and travel depends on the shocks you have you at least need the walker Evans because the stockers at least with the stock springs cant handle the pressure. but with my fox shocks we took a very grude measurement at 14" travel front and rear
Bruce4795
112
248
Arizona
Bruce4795
112
248
Arizona
I’m considering your full kit for my Pioneer 500. I have Walker shocks. Curious if the A arm brackets on the frame need reinforcing as well? Will I need new wheels also...mine are stock. What is the estimated ground clearance, wheel travel, and width with the kit? I presently have 10 inches of ground clearance with 26 inch Big Horn tires.. How battle tested is the kit? Not sure I want to be beta testing it since I get into very remote areas. Thanks very much.
Bruce
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
Bruce
ive been build these for awhile now and you are even in the first 20 lol you can gain up to 5" of lift depending what springs you run and if you have stock wheels you will need 1" spacers to clear the ball joint plate you will be 62" wide
Bruce4795
112
248
Arizona
Bruce4795
112
248
Arizona
Thanks! So no A arm attachment point failures up until now?
Bruce
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
thats a factory issue and not from my kits if its going to happen then it will happen but it comes down to how hard you ride and push the maching
Bruce4795
112
248
Arizona
Okay, much appreciated! I’m fairly conservative in riding.
Bruce
Reactions: jak9922
Bruce4795
112
248
Arizona
you wont have any issues then its mostly hard riding with big tires that cause issues
Is it possible to dial back the ground clearance with my WE shocks to say an additional 2-3 inches instead of 5 inches? I’m trying to keep increased stability for off camber stuff. Thanks for putting up with my questions.
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
the 5" is just the max height if you crank your preload and at 62" the stability is absolutely amazing on insane off camber rock and hills it does not want or feel like it going to flop over
