highpocket74
Bent an a-arm in Arkansas. Thinking about changing lowers on all 4 corners now. I’m unsure about the aluminum rods though. Like S3 stuff because they are in Louisiana.
How long did the first set last? I just installed them on my talonx-4 was wondering if I should buy a spare set.I run L&W front and rear. They have been tough but installed my second set of bushings in the rear radius rods. I just installed AJK Radius rods and they are very nice and seem to have much better bushings.
Noted Slowpoke.Do yourself a favor and use 5/8 heims at all 4 locations and use bushings to reduce the hole to fit the stock bolts. I used to kill 1/2 heims in my Raceco radius rods in two races before moving up to the 5/8 Raceco setup that has been trouble free ever since. Also, name brand Teflon lined heims are what you need to use. The China "heat treated cromo" heims most off road vendors sell are junk and will loosen up in a few rides. They are no better than tractor link heims
Noted Slowpoke.
I think these are 3/4" heims but will have to look back at what I sent the builder.
I made an error and did not realize the outer side was a larger diameter shoulder bolt. Tried to install these yesterday and it was a no go only because of that. Contacted the builder and they are working on correcting this for me.
