P500 Loss of electrical power
Trider1
Trider1
42
171
Blackfoot Idaho
I have a 2016 and have never had a issue with it till now. I am on a hunting trip 600 miles from home. While driving yesterday it just shut off and left me stranded. I checked the fuses and battery connection and it fired right up. Today the same issue but after I turn it off.
Anybody else have this problem?
Reactions: DG Rider
70Bones
70Bones
888
3,779
New Brunswick Canada
Can you give us a bit more info? When it quits, does the dash display go off? Headlights work? Any dash lights on? Been in deep water lately? Any other info you can tell us?
Reactions: DG Rider
42,987
Never had it happen personally.
When you say shut off, did the gauge also die...IE, zero power to anything?
Did you tighten/clean the battery cables? I'd start there. Maybe swap some relays if it dies again. Could also be the ignition switch, though usually they will give you some warning before they completely die.
Also, check the wiring for rodent damage.
42,987
Sorry @70Bones, we posted at the same time.
Reactions: 70Bones
Trider1
Trider1
42
171
Blackfoot Idaho
No display and no deep water. I keep it in a covered trailer. I have not had a chance to check the lights as I left it on the property we hunt.
Would it be the solonoid by any chance?
Trider1
Trider1
42
171
Blackfoot Idaho
Wires all look good I chased them down thinking the same thing with mice or melted wires. The only thing I noticed is I get a hiccup in the idle before it occurs. I loosen the + cable and retighten it and its good to go until it does it again.
I have not noticed any power loss while it is running.
+ cable is not corroded and looks really good. I have not driven it hard since last August but she behaved riding around the house before this trip.
Neohio
Neohio
Beast of the East
14,573
73,616
Painesville Ohio
Original battery?
Do you have a jumpbox you can carry with you?
It may have a cell going bad.
Trider1
Trider1
42
171
Blackfoot Idaho
Original battery?
I replaced the battery last may. I have plenty of cranking power when it starts. I have a light bar + 2 four inch pods and have not seen any dimming while running.
Without a voltmeter here to check things out I am at a loss for now.
