P1000 Lovin’ me some Side Lights - Nilight super slim LEDs
jhall2242
14
31
WV
4af5be9873b1b3f414e12f80a7b2dc6f
I thought adding some side lights would be handy after the front and rear lights. After a month I think the side lights are my favorite mod. Very compact. Dont stick out. The spot lights are perfect for seeing out into fields as you drive. Can easily see 150 yards plus see what is close to you. You have no idea what you are missing till you try them at night. Gives you 360 degree visibility.
Nilight Led Light Bar Super Slim 2PCS 7 Inch 30W Spot Driving Fog Light 3600LM Single Row Off Road led Lights for Jeep - 2 Style Mounting Brackets, 2 years Warranty https://www.amazon.com/dp/B0197ZQLBA/?tag=sxsweb24-20
jhall2242
14
31
WV
3c7e595ba73671ca4233e5e714ae0aa9A85d455114a11d1d2246b970a53f8cf73e81202df3a8b962e5a82c4c67b47bad3e96f9ccead3b53bb4ed67a57db5ba1d
Stick down from roll bar about 1.5”. Stick out about 1.75”. Had to cut off the mount arms and drill a new hole in them to make them compact. Was not hard since they are aluminum. Used a black paint pen where I cut them off. The house in the picture is about 150 yards off.
Reactions: Deluxe700
I just added one to the dirtbike for anhead light.. they seem to be good little lights.
jhall2242
14
31
WV
Those mounts suck! Look at the TSC mounts.
Ok. They work great so far. Where might I find these amazing TSC mounts?
Reactions: mgm1035
Deleted member 3748
I like the TSC mounts and I like the Tusk flag mounts. You can get the Tusk in vertical, horizontal, and adjustable for $10 each.
Tusk UTV Vertical Flag Mount
I like the idea of side lights too, but it looks like something I would hit my head on a lot! :eek:
I also have a few of the Nilight brand lights. They're a few years old and still working.
jhall2242
14
31
WV
I am 6’3”. I thought I might hit my head but so far it is not an issue.
Yup.. any mount that uses a screw on each side will give you a better fit and less aggravation mounting.
mjn
mjn
1,409
5,206
SE Washington State/N Idaho
The side of my roof slides along trees all the time. I'm afraid that would get ripped off in short order. I do like the idea because I have them in the back.
First thing that came to my mind too. Every time we come back from a ride there are branches & sh!t stuck between the roll bar and the roof..
Cool idea though!
Reactions: jhall2242
jhall2242
14
31
WV
Cool idea though!
I try not to hit too many branches but the lights are tough and only about $10 each if you did smash one. Also you could rotate them back under the roll bar. It just doesn’t give you as much light but still would work fine.
Reactions: mjn
They don’t take too much of a beating as you can tuck them behind the roll bar... but with that said one of mine are currently hanging by the cord! lol
Side lights....yup I love them too.
03682879d64cdad554fb9119a69c0814
7f7318a7d22bd3739e64540b3ba9f690
All tucked away because even my Velcro grab handles have been ripped of a couple times.
These X5’s are bright!
3b96b9207969d765abd358c149b3cc6c
E35ba1385814558686a46e297bfc0ffb
Ragnar406
Ragnar406
The Great Bald One
4,450
17,035
Bella Vista, AR
@joeymt33 Looks like you removed the seatbelt housing cover can have the light bolted on that forward bolt - is that pretty accurate?
Upload 2018 8 2 7 55 20
I was looking last night at using that bolt but was going to try and build out with a spacer - did not think of removing the cover.
You are correct sir.
I was thinking of removing the whole seatbelt mechanism completely because it’s never used. But I guess it doesn’t hurt to stay there.
