P1000 Lower front bushing fox shocks
Hondaman67
65
137
Arkansas
I bought a set of fox shocks for my 1000-5 base model. There is slack in bushing on lower mount of front shock between rubber washers. It's almost like rubber washers that came with shocks should have been wider. Has anyone noticed this and is that normal? Thanks
20211212 123631
115,818
Have had mine on since 17’ and are the same. thats the bushing sleeve. The rubber is to keep the fit tight where it mounts like in your pic.
In other words, your good! Go ride!!
Ragnar406
Ragnar406
The Great Bald One
4,450
17,035
Bella Vista, AR
Those bushings are a wear item - if you look at the parts layout for an LE model you can see all the parts and their numbers to order and replace - note there are different sizes for some of the items between front and back and top to bottom ...
Front
1639413559080
1639413608992
P
PioneerDuluth
26
53
Duluth, MN
I'm looking to do the same thing to my base 1000, are you happy with the improved ride quality? Would you say the ride gains are in line with the cost?
