P1000m5 Make pioneer more stable
N
Noble1
Grand Rapids, MI
I recently purchased a pioneer 1000-5 and looking for a way to make it more stable.
39,079
I recently purchased a pioneer 1000-5 and looking for a way to make it more stable. In the one week I have owned it my kids have put it on its side two times. While I understand it is more of a utility vehicle I am wondering how to make it a little more stable. Any one running wheel spacers? I am looking to purchase some different wheels and tires and possibly some wheel spacers. Maybe just some wheel spacers on stock wheels and tires? I plan on hitting the trails in MI and not sure if the added width would be of concern. Any advice would be appreciated.
I know the best advice would be to keep the kids out of it. Lol.
Seems crazy that they did that. What type of terrain. When that happens to me it’s always doing some side hilling that I shouldn’t.
Anyway, mine is 2” per side wider and after 2000+ miles the bearing are still good. You could chop the top lower if you’re not too tall. I’ve dropped mine 4.5” and I’m 6’. Seems to fit me good.
Reactions: Delton and JTW
N
Noble1
Grand Rapids, MI
Crazy enough they are on my property and it is flat. Now they have made a bit of a trail/track and both times it has been in a corner so they are just too hot in the corner. Lol. Do you have the spacers on stock wheels?
Reactions: joeymt33
319,918
The fox shocks have definitely made ours more stable as did the roof chop. Wheel spacers will help obviously as will a slight tire pressure increase.
39,079
I do run spacers with stock wheels and aftermarket wheels. My STI wheels have one inch more back spacing vs stock.
swsebek
swsebek
2,854
5,828
pa
Never even got dirty yet.They will break and arm or a neck at that pace.Spacers will make it more stable and also be more violent if they do flip it... I would listen to trigger or privileges would be taken away. Eventually it will bite them.
N
Noble1
Grand Rapids, MI
Thanks for the reply’s... just to clarify my kids are young adults and like to push the limits in about everything they do. They have both put it on its side and think they now understand its limits. I think I will order some wheel spacers 1 1/2inch? and increase the air pressure as well. What PSI would you recommend? Was looking at different tires as well...something with a stiffer sidewall?
Fox shocks maybe down the road.
Thank you for your input
39,079
1.5” would be good. On my stock tires I run 18-20psi but my rig is very heavy.
If you want a stiff tire, it doesn’t get much stronger than the Roctane by STI.
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
You don't need wheel spacers. They need to learn how to drive before someone gets killed. Add spacers and they'll just roll harder next time.
156,744
I have had mine on some off camber situations and felt pretty stable, I’m guessing speed is at fault there. I don’t care if they are young adults my kids would still get an ass whopping if they did that to my s***.
My thoughts as well, the problem isn't with the machine. My boys can destroy their own sh** all they want but better have some respect when using mine.
