P1000 maxxis carnivore
Riverrat1
Riverrat1
17
West central illinois
Has anyone tried out the maxxis carnvore tires yet in the 28x10x14? I recently ruined a rear stock blackstone so need to get something different. Just looking for some opinions or info on these for the pioneer. Thanks.
GlockMeister
GlockMeister
The Bearded Wonder
7,604
35,567
Greenville, Mo
@PioneerPete is running them. They look awesome. I am still trying to decide if I'm going to buy a set myself.
PioneerPete
PioneerPete
1,496
3,516
Chattanooga, TN
I'm running the 28x10s and I love them. they barely measure 27" when mounted and aired down to 12psi, but I have been very happy with them. no lift required.
Reactions: sharp and Plumber32
PioneerPete
PioneerPete
1,496
3,516
Chattanooga, TN
Will one need lift with a true 28" tire?
the guys with the 28" roctanes rub on the rear of the fender... from what I understand, a lift isn't needed, but may want to get forward arched arms. depends on how much scrubbing/rubbing you're willing to put up with.
Riverrat1
Riverrat1
17
IMG 20170123 152425524 HDR
X4Dice
X4Dice
87
130
USA
How do they do in mud? If I remember you don't have you lift installed anymore?
Reactions: sharp
Riverrat1
Riverrat1
17
Thanks. I removed mine first thing when i got it home. Only have used the rear seats on a couple occasions and the rear rops would just get in the way to often for me.
Reactions: sharp
looks great, what wheels did you go with, 5+2 spacing? I'm looking at the same setup. any rubbing? I see that PioneerPete went with a different spacing 3.5+3.5 and he said he didn't rub.
Thanks
I thought @PioneerPete had 4+3 offset
Reactions: sharp
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
5e060f6c3158af723e577ddb818e45e4
0dad481b6450593d43be76e7864e4772177f68d6cf614b9ace4546c94872820d
Here's my tire size. They only rub a little bit when you turn and compress the suspension just right. They are only about 8" wide on the tread so I'm sure that makes a difference.
Reactions: JTW and sharp
