P1000 Mirrors and doors
HappyCamper
59
103
Wyo
Has anyone found any side mirrors that work well with the soft upper doors for a 1000/5 ?
Reactions: Lady01 and TxDoc
HBarlow
HBarlow
1,634
6,084
Daniels, WV
Yes. I'm using Honda accessory mirrors.
IMG 1988 IMG 1987 IMG 1980 IMG 1982
HBarlow
HBarlow
1,634
6,084
Daniels, WV
A metal bracket attached to the upper door frame.
I posted photos of the bracket on another thread of a similar name a week or ten days ago.
Reactions: Lady01
HappyCamper
59
103
Wyo
So, if they're attached to the upper frame, they must come off when you remove the uppers, right?
HBarlow
HBarlow
1,634
6,084
Daniels, WV
That would be correct but I never remove the upper doors. Summers are mild in WV so all I need is to open the upper half of the windshield for air flow.
I was in a hurry earlier this morning because I had a dental hygiene appt. Here's a link back to an earlier thread on same subject where I posted a photo and explanation of the bracket I use.
I spent $200 - $250 buying several different pairs of mirrors online before I obtained and installed the bracket and Honda mirrors. None of the mirrors I purchased were satisfactory WITH my fabric upper doors. The right outside mirror was a challenge to see from the driver's seat with the Honda fabric upper doors.
The Honda mirrors are the only mirrors I've tried that are functional and completely satisfactory.
HappyCamper
59
103
Wyo
For me they would be completely unsatisfactory. I need mirrors that will remain in place when uppers are removed. The uppers to me are just a necessary evil for winter time. I love the openness for spring through fall. Anyone else have a solution?
Reactions: Lady01
HBarlow
HBarlow
1,634
6,084
Daniels, WV
No problem then. You can select from a dozen or more mirrors that attach to the A pillar. You'll be able to use them in summer with the upper doors removed but the right side outside mirror will be a useless appendage hanging there where you can't see it when the uppers are installed.
HappyCamper
59
103
Wyo
I've bought two sets of mirrors so far that will not work with the uppers installed. There is no place to attach them on the A-piller because of the upper door hardware being in the way. I've thought of putting them higher on the A-piller but they'd block too much of my view and be unsafe in that location. I really don't care to even have a right side mirror, but I need one on the left. So far the inside center mount rear view has been adequate for most things but I'd sure like a left side mirror for a number of reasons. Frankly I'm a bit surprised that there aren't more comments on this thread. Maybe not many folks on here use these upper doors or just do without mirrors if they do.
Reactions: Lady01
TripleB
TripleB
15,618
140,488
Caryville, Tennessee
See if this might help u.
Reactions: Ohio4x4 and Lady01
tjoreo
tjoreo
1,025
1,975
Southern Idaho
If you take a look at what @HBarlow has posted from the other thread it shows a picture of the mount and you might be able to come up with something that will work. The honda mirrors will attach to his pictured bracket in the winter, and when the summer arrives you can just unbolt them and reinstall them on the honda mounts. 4 bolts and your a swapped back for the summer.
Reactions: Lady01 and HBarlow
HBarlow
HBarlow
1,634
6,084
Daniels, WV
See my post and photo in this thread:
PM me if you have questions after seeing my post.
Reactions: Lady01
