P1000m5 Mirrors with soft doors and windshield ??
Dirtstiffs-1000
Dirtstiffs-1000
1,729
6,241
hondasxs.com
I need some of those. I assume he is a member here and can be contacted thru the site? How much for a set?
Also, how are you mounting the mirrors in the summertime when you take the upper doors off?
Thanks a bunch!
Yes, a member.
PM (private message) @tjoreo .
I have Honda OEM mirrors that clamp on the A pillar, when the doors are off In summer.
2 bolt swap each mirror between summer and winter mounts. Quick and easy.
tjoreo
tjoreo
1,032
1,992
Southern Idaho
Very nice work. The brackets appear to be exact copies of the ones my friend made but made of a synthetic material.
@HBarlow Actually I came up with the 3d printed version as well. I had the file saved based on the aluminum version that you came up with your instructions for. I made @Dirtstiffs-1000 a set of the aluminum brackets and told him I was toying with the idea of making some 3d versions to hopefully help more people out. I figured no time like the present so I made a set and sent them to him and he has been helping spread the word that these might be an option. I have been having a little trouble with the quality of them but believe I have an idea to make them stronger. Version 2 is on the way with the hopes to help more Honda users out. I guess it is a good time of year to work on the design as a lot of people like myself are pulling their doors off, so hopefully I'll have dependable version soon. Hope you are doing well Harvey and as always Thanks for your friendship.
HBarlow
HBarlow
1,636
6,066
Daniels, WV
You're a good man, Seth.
Reactions: tjoreo
shaundeere
14
Care to share the stl files for these?
GROR
GROR
74
275
Castle Dale, Utah
ghostrocksoffroad.com
A-Pod HSD Multi-Pod & A-Pod Mirror Bracket: Custom-made for Honda OEM Soft Doors.​
FITS: 14-25 Honda Pioneer 1000-1000-5-1000-6
Our A-Pod Brackets are made specifically for the Honda OEM soft doors. We have two bracket configurations available: the A-pod HSD (Honda Soft Door) Multi-pod that will also mount a 50-54’’ lightbar, and the A-Pod HSD mirror-only bracket. Both models have a 10mm bolt hole, and we provide a 10 mm-8 mm reducer so that the brackets will work with various 10 mm and 8mm single-bolt mirrors. When we tested mirrors, we found that the tusk mirrors worked the best. However, we only tested the Seizmik Embark and never tested the Seizmik Pursuit or Strike UTV Side View Mirror.
Testing included running the mirror into trees at various speeds, which was nothing extreme, but if you wondered why the brackets are made from 1/4'' steel, there's a reason. The A-Pod Brackets' Solid steel construction is designed to withstand the most extreme punishment, allowing the mirror to fold in when hit and return to its original position in one move.
A pod MB
A POD HSD 2 IN 1 LIGHTBAR MIRROR MULTI POD
MB FOLDED
MB FOLDED FORWARD
MB FOLDED FORWARD
20231003 073021
Vikes79
Vikes79
SKOL!
12,000
115,411
South Dakota
  2. Talon X4 LV
I have the kemimoto version of these for the better part of 3 seasons now on my 2018 P1k5. Works with or without the windshield or doors and are pretty darn tough.
SHEJISI UTV Side Mirrors for 1.65"-2" Roll Cage, Aluminum Solid Bracket,2023 New UTV Mirrors,Adjustable Satisfactory Viewing Angle Compatible with Polaris RZR,Can Am,Kawasaki Mule,Honda Pioneer SXS
https://www.amazon.com/dp/B09JFSN3TC?tag=sxsweb24-20
Reactions: SingleEntendre
HBarlow
HBarlow
1,636
6,066
Daniels, WV
Your products look sturdy and professional but can the driver can see the right-side outside rear view mirror from driver's seat?
The significant advantage of tjoreo's bracket design is both outside rear view mirrors are comfortable visible from driver's seat.
Ducky20
0
New Jersey
Would you be able to send me the stl or g code for theses?
