P1000 Moose RM4 Snow Plow System
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Does anyone have this plow system installed?
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Still waiting on the Blade but have the sxs mount and blade mount...so thought I would mount what I have...
IMG 5750
IMG 5792
Reactions: CumminsPusher
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Ran into problem as seen in these photos...
IMG 6020
IMG 6026
First mount is too wide at bottom bumper location...so ran to hardware store and got longer bolts and washers to act as spacers
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Got it centered...
IMG 6030 IMG 6032
And moved top part of mount into location...
IMG 6025 IMG 6022
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Using atv jack to lift bracket into place but it hits before sitting flush against bumper! Here is the gap...
IMG 6029
Eltobgi
Eltobgi
4,599
15,186
North Dakota
If anyone has used this plow system would appreciate some advice!:oops::oops:
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Thought maybe wrong mount but...
IMG 6034 IMG 6033
Eltobgi
Eltobgi
4,599
15,186
North Dakota
IMG 6038
Was trying to put it together pending potential help on installation, but... winch is acting up due to cold temps...so had to hold it up with ratchet strap...
IMG 6036
A little help with atv jack
IMG 6037
tjoreo
tjoreo
1,024
1,963
Southern Idaho
I can't speak for the mount itself, but I do find it kind of interesting that it fits on both the 1000 and 700. I have the factory (warn) mount on my 700 and it fits pretty well. I just looked at the 1000 factory mount and it looks like a complete different beast with a bushing welded on it to take up the space. Just makes me wonder myself if the denniskirk has the wrong info, but it looks like you are going to get it to work fine. I do have a moose country plow blade that I picked up for cheap and extended to accommodate the width of the pioneer. The blade at least seems to be very well made, and I think you will be very pleased after you get it all mounted up. Enjoy.
Mike129
Mike129
125
240
Iowa
I have a moose plow for mine. Not exactly sure on model. I can check tomorrow when I get off work and let you know. It looks different from your setup though. Where you located at? It appears we are having some of the same weather. Wind chill to almost -40 is forecast for my area in central Iowa.
Sent from my SM-G900V using Tapatalk
Eltobgi
Eltobgi
4,599
15,186
North Dakota
North central North Dakota...its passing now so looking forward to near freezing temps! Thanks for your help! Please post some pics of your set up for me:)
Oh ok just saw your avatar has the moose plow set up:rolleyes:
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Well...emailed Moose and called Denniskirk to resolve issue! But I'm thinking I will have to return it:(. Really disappointed because the quality of this product is top notch!
Might have to go with this...
IMG 6040
Any Reviews guyso_O
tjoreo
tjoreo
1,024
1,963
Southern Idaho
I'm sorry to hear that. I was doing a little look for you but couldn't find out any real answers myself. There was a product number for the mount for a "Pioneer and Pioneer-4 14-16" so I would assume just the 700. The undermount is different between the 2 models, so I would assume the R4 version should be different. Good luck anyway you go.
Mike129
Mike129
125
240
Iowa
Mine in an under mount system. I just have to drive over it and put in two pins and then hook up my winch line to lift the blade. Hope the pictures help you. 0017258c831cb2d5f78b4c99b0587d4a8301386f2bd470ee89060b92f3af9812
Mike129
Mike129
125
240
Iowa
The second picture is kind of hard to see, but there is a flat plate (bolts to undercarriage) with two tabs (one for both sides the push tube)where the cotter pin goes in to connect the plow.
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Look HD! Does the mounting plate use pre existing hardware? I can see a few bolts in the photo. Also, how is the side to side movement?o_O
Mike129
Mike129
125
240
Iowa
Ce25965db5bda71a4078225e8e2052695b4412930a701b322c465ba95baf1f70E00e77be3517d0595c5a1562697c38ec
Mike129
Mike129
125
240
Iowa
This is my setup. I've only used it a couple times this year, but so far I'm pleased with it.
Mike129
Mike129
125
240
Iowa
The hardware I am not sure. It was installed at my dealer when I bought it. What do you mean side to side movement?
tjoreo
tjoreo
1,024
1,963
Southern Idaho
Dennis kirk has the instructions for the mount online and it looks pretty simple to install. Just the 2 bolts in the front and 2 underneath. The only disadvantage I see with the undermount ones is the limited height you can lift it. My shed is pretty tight, so it's pretty nice to be able to lift it up and about set it on the hood if I want. Makes the headlights useless though because they are covered with the plow.
