P1000 Moose RM4 Snow Plow System
Eltobgi
Eltobgi
4,599
15,187
North Dakota
Stock suspension and tires on mine.
Sent from my SM-G900V using Tapatalk
So with the highlifter lift maybe a few more inches of lift;)
Do you run the side shields?
Reactions: CumminsPusher
Mike129
Mike129
125
240
Iowa
I don't run the side shields. I do have one question though...I just bought the side markers for the edge of the plow. I don't see a good place to bolt them on and I cannot imagine I am supposed to drill holes to mount them. Any thoughts?
Eltobgi
Eltobgi
4,599
15,187
North Dakota
Could use a short flat strap from one of the end carriage bolts that hold the rubber flap on, or maybe an L bracket. Of course you would have to get a longer carriage bolt. The only other way would be to add side shields and attach to them, or drill holes like you are suggesting (which would be the easiest).
tjoreo
tjoreo
1,032
1,992
Southern Idaho
On mine I just used one of the mounting bolts for the flap and had it tipped at an angle. I wasn't too impressed with the moose markers I put on and after one winter I had them about ripped off. My good friend is a snowplow driver and he gave me a set of these. Way better with the size and cable reinforced and for about the same price.Winter® Plow Markers 30” | Winter® Equipment Company
Reactions: Eltobgi and Mike129
Eltobgi
Eltobgi
4,599
15,187
North Dakota
Like the design with two mounting bolts per marker rather than one which could swivel! Thanks I'm going to order a set!
Reactions: tjoreo
tjoreo
tjoreo
1,032
1,992
Southern Idaho
I had trouble with mine tripping a lot which put a strain on the moose markers. These have the cable inside so they take quite a bit more abuse. The 30 inch is kind of overkill but I think a guy could cut them shorter if they want.
Sent from my SM-T350 using Tapatalk
Reactions: Eltobgi
