DDDonkey
Asking for a friend........
So looking at getting a tuner and there still does not seem to be too many options, please correct me if I'm wrong but all I have found is below.
1 - Stock ECU with the PCV and AT.
2 - Stock Talon ECU, but still need PCV and the dash 4wd indicator will not work
3 - Send ECU to Sibler Turbo and have them re-tune it, but no one knows what they do to the ECU and there is no dyno sheet to see the gains.
Is there anything else out there other than a muffler? Also if you put a Talon ECU or order a second ECU and have it tuned is it just plug and play or do you need to preform a relearn of some sort? Looking for more low end power as I have found a few spots, even in low the pioneer did not have enough power to start moving from a stop, had to back up and hit it with a little momentum.
Again asking for a friend....
