T
just starting my vent lines and was wondering what vent line is the most important vent line that needs to be extended first if you are limited on time. going to do them all overtime. and where are do you run the extended vent lines.
Joeymt33 where did u run the new vent lines to I got my gas tank vent line done and run to the roof going to try and get to get the rest done this weekend
Radiator fan, sub trans, coolant overflow, and fuel tank I ran all the way up inside my roll cage. I drilled breather vents at the top. The front and rear diff I used bellows, don’t have to worry about running extra line with them. Her are a pic of my bellows. All vent lines and bellows only took 30-45 mins.I ran all my vents up behind the back of the seat just below the head rest. I did use some small fuel filters on the end of them as well.
The front two vent lines are up under the hood next to the batteries.
Consider replacing those bellows and adding lines.View attachment 70241 View attachment 70242
Well s***, looks like I will be running vent lines for them. Haha thanks for the heads up.I installed bellows on my pioneer 1000 back in late 2015 when I got it. After it pushed out the pinion seals on the differentials I realized that was not a good thing to do at all. It happened running high speed on a hot July day and the Bellows had been installed for 700 miles until it happened. Just wanted to give you a heads up
will adding chainsaw filters prevent this. I think its from where gas fumes attached to the dust making in look bad. it freaked me out at first. one hose is the gas vent the other is sub transmission vent. I purchased the kit. witch is very easy and highly recommendedI ran all my vents up behind the back of the seat just below the head rest. I did use some small fuel filters on the end of them as well.
will adding chainsaw filters prevent this. I think its from where gas fumes attached to the dust making in look bad. it freaked me out at first. one hose is the gas vent the other is sub transmission vent. I purchased the kit. witch is very easy and highly recommendedView attachment 70419
ordered the same ones u have. bugs and wasp are a nightmare round where I live. how often would u say the filters need to be changed?I’m not sure because I’ve not seen that residue yet. Do the filters anyway because it will prevent bugs and dust.
