P1000 Mud Busters vs. Honda Fender Flares vs. ?
Amre2me2
Amre2me2
381
1,423
Colorado
Fender flares should never be rigid. The first tree you slide up against will bust them up. I couldnt find what I liked so I built my own. Made them out of conveyer belt material from a local gold mine. They are tough and will never get damaged but they flex when I get too close to a tree. I don’t ride on nice groomed trails so any of the rigid type would just be a waste of money. They gave me enough material to make dozens and it was free.
4FD9FF34 8245 42E9 8C85 CCCDF4B98319
BigOL3
BigOL3
2,994
8,920
Likewise ............
1612963783504
1612963881437
Ridinfool
Ridinfool
36,144
386,046
Western North Carolina
Ok, rode my stock P1K Dlux at RRB last May mud was not bad.
Changed stock wheels and tires to 28-10-14 with a 5+2 wheel and a 1” spacer in back, I’m about 1 1/2” wider than stock.
Rode RRB in September... mud EVERYWHERE!!! Boss (that’s the wife) said I better get some mud flaps or she ain’t riding no more...
So, after a long, long battle with myself I ended up with the mud busters xl front and rear.
went for a ride in the swamp, in central FLA this past weekend and zero mud in the cabin. So far I like the mud busters... a pain in the azz to install but worth it IMHO.
sjacobson48
sjacobson48
24
87
Ridinfool - I have the exact same set up that you do, but I'm getting a lot of tire rubbing in the front now when the suspension travels deep. Never had that with the same tire set up before putting the mud busters on. Hard to believe the thickness of the mud buster alone was enough to make that big of a difference, but it has. Are you experiencing any rubbing on yours?
Perhaps I tweaked the plastic some when installing, and was hoping it would work itself out.... but it hasn't. I don't think it will rip anything off.... but it's annoying as hell when hitting the bumps.
TripleB
TripleB
15,618
140,489
Caryville, Tennessee
F8b2f5941b1b8122cc24efb1b4c50453
1 self tapping screw inside the red circle will solve your problem.
Ridinfool
Ridinfool
36,144
386,046
Yes, I have the same issue, although it didn’t bother me until this past weekend at the Take Over, I bent a tie rod and it’s worse, the fix @TripleB shows will do the trick, I just haven’t done it yet. Another member had the same issue and fixed with a self tapping screw.
