Need guard under floor boards
Teammontana
Teammontana
24
44
Arkansas
2018 Pioneer 1000/5. Twice now we have flipped large sticks upward into the frame rails under the floor boards and had them go through the floor barely missing our feet. Once on each side. The frame has no skid plate along the outer edge and sticks get kicked and wedged against the rear cross frame forcing them through the floor. I can make a skid plate to cover that area but thought I would see if anyone was making this part. Luckily the push rivets gave way and the plastic floor wasn’t busted. Pictures show one of the results of the puncture and the log I removed.
04AF1B81 42DC 46BF 9F59 85BA35C5577E 93CB1021 3B5C 494B B4EF CA1573F6A242
Buggyman
Buggyman
44,124
357,470
ne. ohio
View attachment 360597 View attachment 360598
I had an old tie rod off a truck come through the floor on mine, hopefully the full skid plate will prevent that from happening again.
271,887
This is what you need, FUTV Ultimate skid plate set. Full info here: Why Run Full Coverage Skid Plates / A-Arm Guards
OEM
OEM Plastic Installed
FUTV full Skids
FUTV Ultimate 50 Kit Installed
russknight
russknight
1,910
7,509
Perry Florida
I installed the Ricochet Rock sliders as well after doing the same thing. Heard several sticks break when hitting them since then. Changing the firewall out is a royal pain. Don't want to do that again.
Buckshot2
Buggy blue
Prntckt
Prntckt
1,092
7,608
Altoona, WI
  1. Talon X4
Robobrainiac
Robobrainiac
2,550
8,957
I recommend a full skid plate as well. I use the SuperATV. It is cheaper than others in the 1/2" range when you catch it on sale. I bought mine last year on black Friday for $580 shipped/taxed.
Bow4life
Bow4life
129
540
Minnesota
X2 on this....throw the factory one away and get a real skid plate....they're spendy but worth every penny for the protection you get.
ODAMO
ODAMO
1,283
3,450
Ohio
russknight
russknight
1,910
7,509
Perry Florida
It’s the honeycomb area that adds to the danger of stick penetration as it grabs the end of a stick. The added piece that Honda covered that with should serve well in deflecting sticks. It looks like it can be added to prior years.
Mine came up through the floorboard.
Reactions: Buggyman
TripleB
TripleB
15,119
134,769
Caryville, Tennessee
I had a stick poke through the honeycomb area.
