need help!!! Aux power wire.
Y
Yoshimtz2
I do not have the manual, and install the winch, but I need to know which wire is the power cut, someone could help me with that, a picture or manual to know which is, thank you very much, really appreciate it.
translated using google translate
Re: need help!!!
There is a black/white wire on the back side of the fuse panel, look at the instructions for the Aux switch panel it tells you exactly which wire it is.
67,230
[album]608[/album]
Here is the instructions in print so it can be translated.
#8. Remove the fuse box cover.
Release the fuse block from the side of the
compartment using a small flat blade screw driver to
release the locking tab.
#9. Turn the fuse block over and connect the power
harness wire tap connector to the White/black wire
in the position shown. Be sure the tap connector is
locked closed.
- White/Black wire is on second row, fith wire from left
Y
Yoshimtz2
I'm not sure that's what I want, I say the cables are on the side of the steering wheel coming from the ignition switch, to turn on the car and has power the winch, or turn it off and shut off power to the winch.
Translated with Google translate
That wire on the fuse block is switched with the ignition. When the switch is on the wire has power when it's off it's without power.
Y
Yoshimtz2
Well, try it, right now I say if it turned out, and send you pictures of winch already installed, choose to keep it simple is always better to do, so the mount winch, is no big deal, but it has 4-point restraint with 8 screws total plate and the winch is mounted with 4 screws, the cable can deliver very well up and down as well as sideways, without touching defense, then to avoid problems with bending or reaching the same cable.
Thank you very much for the help, clarify doubts and for the prompt reply :)
