So I am in my garage hooking up my true isolator and my auxiliary battery. What common ground did y'all use to ground it. Also, where did you tap in to the ignition power for the voltmeters? Thanks!
I drilled a ground into the chassis that is above where the battery is. I also use this to ground my ground block.So I am in my garage hooking up my true isolator and my auxiliary battery. What common ground did y'all use to ground it. Also, where did you tap in to the ignition power for the voltmeters? Thanks!
It doesn't plug into anything.View attachment 29631 OK, this may be a dumb question but where does this orange block plug into the directions show it sitting by itself but do not show it plugged in anything
Pweh!! I knew I wasn't mechanically inclined but I was like what the hell lolIt doesn't plug into anything.
I had a simple diagram drawn up but I can't find it. It's been a while since I did mine. The orange block is a relay red is power black is ground and you hook the gray wires from the meters to each of the green wires.Pweh!! I knew I wasn't mechanically inclined but I was like what the hell lol
Exactly! Don't over think it, take your time and just do what it says and you'll be fine.@Jimmyscoin... Remember when I said take your time and draw it out? Lol. This stuff isn't hard, but it can be confusing. I have an electronics background and it still took me a while to figure out exactly what I wanted, how I wanted it, and how I was going to get it done... lol
Lol!! All right, so I have it all wired up everything hooked up everything is where it supposed to be except when I turn the machine on the blue light comes on the isolator tell me that it's working but my voltmeter gauges do not light up. Everything is running to the same ground so I figure the ground is good because the isolator lights up but it must be a power issuePut that thing on a trailer, stop by the Class VI Store for a bottle of Glenlivet, and head on down. We'll get you wired
Did you use the relay?Lol!! All right, so I have it all wired up everything hooked up everything is where it supposed to be except when I turn the machine on the blue light comes on the isolator tell me that it's working but my voltmeter gauges do not light up. Everything is running to the same ground so I figure the ground is good because the isolator lights up but it must be a power issue
You need to ground the relayLol!! All right, so I have it all wired up everything hooked up everything is where it supposed to be except when I turn the machine on the blue light comes on the isolator tell me that it's working but my voltmeter gauges do not light up. Everything is running to the same ground so I figure the ground is good because the isolator lights up but it must be a power issue
