P1000 Need Help with removing pin from relay.
Bighat
Bighat
899
3,831
Gallipolis Ohio
Trying to install and accessory and following the instructions it want's me to remove a pin from one the factory relays and install their wire. I have tried to remove it every which way I know but with no luck. Anyone got any pointers?
Mark in Northern Iowa
490
2,193
Floyd County, Iowa
kramnella.wixsite.com
From the relay or from the relay harness?
To my knowledge, relay blades/pins are not removeable.
From the harness, sometimes you have to slide along the connector to push in a little tang to release the connector.
Have a good day
Reactions: Lady01
Cely1932
Cely1932
91
591
83
Loveland, CO
The process....
20220225 162325 20220225 162331 20220225 162350 20220225 162421
Bighat
Bighat
899
3,831
Gallipolis Ohio
I've tried that but I can't give to move. I just about screwed up untill I quit and bent it back so I could get the relay back in. Don't know what I'm doning wrong. I worked on it for an hout and couldn't get is to move.
Reactions: Lady01
Bighat
Bighat
899
3,831
Gallipolis Ohio
bumperm
bumperm
1,911
6,798
Gardnerville, NV
In trying to remove the female connector from the "relay base plug", you'll need to apply inward pressure from the wired end, while pushing the tool in to release the little bent tab. Otherwise, the little tab will just dig in to the plastic and you won't get it to release.
Pictures going in would help us determine exactly what you're up against.
Reactions: Plowboy1466
