P500 Need tire advice from the folks that know
fester
fester
5
Boonevilles, AR
Went for a ride yesterday on Mt. Magazine in western Arkansas. Currently running stock 24" tires on stock wheels. For most rides I can go where all the big boys go until today. Today my little shetland met its match. So I am now looking for some more clearance. What is the best way? I am not worried about width as much as cost so I would like to keep my factory wheels. I was thinking of getting 27/9/12-27/9/11 tires. How much clearance will that really give me? Will the benefit be worth the cost? If I'm to tippy I can add spacers later.
Reactions: JACKAL and DG Rider
41,748
As far as tires, you get 1/2 of the overall height increase, in theory. For example, the 27"s are 3 inches taller than the 24", so you would get 1.5" of height gain. I say in theory, because we all know that the stated size of tires is often not accurate, so we need real numbers to get the actual increase.
The cheapest thing would be cranking the preloads all the way to Max (if your model has adjustment on the fronts, as later models do), and call the chiropractor.
Second would be a spacer or bracket lift, if any are made. The right front of the 500 already binds a bit at full droop, so I don't really like the idea of those adding to the problem (the spacers wouldn't do anything as far as that, but again, call the chiropractor for those).
The ultimate solution is @jak9922's long travel kit, but at that point I'd just go buy a bigger machine.
The most common is what you propose with larger tires and wheels spacers to keep things upright.
Lilred500
Lilred500
Keep it on the rubber side
548
1,997
Wv
That’s what I’m running now I haven’t scraped anywhere I used to not even close well worth the cost.
0185760E A6AC 49B5 81B3 8DA0B103D777
NitroxDiver
NitroxDiver
488
918
Concord NC
I Just put 27/9/12 all the way around on my machine. I think that’s about as big as you can go on the front without clearance issues. Check out Chaparral at chapmoto.com that’s where I get all my atv and motorcycle tires. Their prices are hard to beat and their customer service it top notch. If price is a priority I wouldn’t be afraid to go with any of the big horn or dirt tamer knockoffs. Also you will be surprised how much better new tires perform over the stock ones , I can go places in 2wd now that I had to use 4wd in before.
41,748
I have their BH knock offs (P500 - New Tires. ) and I am very pleased with them.
265,434
I put 26x9x12 Roctane XD tires on my OEM rims the day I got the P500. Those oem tires are close to 23" not 24" and the Roctanes run a hair big, they are close to 27" tall. Not a great mud tire but does well all around for trails. That was over 4 years ago, no flats to date.
20150812 094349 zpscm6cjerb
Russ989
Russ989
22,565
146,496
X2, Roctanes are tough!
265,434
Mine were tough as well. Tough to keep air in...
If you run lower pressure they get dirt in bead and leak down. Break them down and clean up the bead really good and air it back up, should stop the leak.
Reactions: Lburou and DG Rider
41,748
Nah. Mine started cracking at the tread blocks. Another member in the thread i linked to had the same issue. Don't know if the cracks went all the way through, or they just let debris get in and puncture, but I was shoving several plugs in each tire after every ride. It was so bad that Discount tire warrantied them out after I started forcing them to do the plugging. If you're gonna run roctanes, run high pressure, cause they don't like flexing.
Reactions: Lburou and 500oneer
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
i dont know about going to a bigger machine over my kit? it basically falls down to what you are looking for because my p5 has more travel and a better ride then my 1k with the fox shocks. or go to a talon if you want a sport machine and need more speed
Reactions: DG Rider
41,748
Prob the closest to a 500 Talon we'll ever get.
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
as far as tires are on the p5 the first thing you need to look at is weight of the tire! being only a 475cc engine in a 1k lb sxs its already working good but the low gearing saves it my 2 fav tires on the p5 are the zillas and carnivores
JCart
JCart
897
2,024
Kamloops, BC Canada.
Ran the stocks for awhile, then went with 5-2 rims in 12” rims running 26x11x12 AMS slingshot mud tires that wear like iron great tire, just rode stiff. Messed about with running stock springs with various length spacers and different stiffness settings on shocks. In the end kept the 5-2 rims, currently running Kenda Bearclaw HT Radials in 27X11x12 on all corners. Rides really well for my needs, that along with Elka Stage 3s, rides handles much differently then stock, really like a different machine, easily 2 gears quicker and pillowy controlled smooth! What I’d recommend is buy radials as they’ll make it ride nicer (in 12” diameter more side wall = smoother ride). Sized in a true 26-27” tall tire, for my 2015 is ideal I’d say. Then if you’re gonna keep it and can swing it get Elka shocks.... thing is you don’t have to do it all at once, taken me from autumn 2014, till last year to get were I’m very pleased with my P5. If you can swing 1 thing.... radial tires, it’ll ride noticeably smoother.
Cheers, happy riding,
j
pFive
pFive
670
1,267
Greenwood IN
I have 30" Interco R-Force on aftermarket rims. This is the lightest 30" tire on the market and the rims are only $45 each (Shipped). Yes, ya gotta cut the frame end off (It does nothing), and maybe spacers would keep you upright longer.. (And toss that sway bar). I don't know about the newer auto shift buggies, but I towed a RZR 1k 4 seater out of the woods last weekend. He had rock crawling tires and blew a front axle, so he was then stuck in 2wd in the mud. After wasting a hour winching up and down hills I just drug him through the mud and up hills to the pavement. So, I don't have any power issues.
Interco also has these in a 27", and those would be a perfect mud/root tire for stock rims and width. Check the interco blem list for a deal.
