I understand the wrench means maintenance required. Do the hours and miles indicate when that service is needed, or is it past due by that much?
They both are getting to smaller numbers as I drive it, so it seems to be a countdown.
correct?
correct?
I believe you are on the maintenance screen. So yes it is a countdown. When maintenance is due that wrench will be lit all the time including the home screen with the normal odometer showing.
