P1000 Need to understand what display means
Herbie
Herbie
86
190
Richmond, TX
I understand the wrench means maintenance required. Do the hours and miles indicate when that service is needed, or is it past due by that much?
They both are getting to smaller numbers as I drive it, so it seems to be a countdown.
correct?
Reactions: Isaiah
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
I believe you are on the maintenance screen. So yes it is a countdown. When maintenance is due that wrench will be lit all the time including the home screen with the normal odometer showing.
5,092
22,890
That countdown will turn to minus numbers like -118, telling me how far past I've gone (Talon though, screen looks nearly the same).
Reactions: Isaiah and Herbie
