Net Removal
Has anyone been able to remove the nets? The bolts seem to be so well seated I am suspecting Honda figured out a way to spot weld them in place to avoid legal issues.
67,229
Ya, they come out. I think they used the red loc-tight. Lol
Put a lot of elbow geese into it and they will pop loose. Don't beat it, U will strip it.
Yeah I have stripped one using a perfect fitting Allen wrench. Didn't mess with any of the others because they are all just as tight. Probably going to have to buy a bolt removal tool.
67,229
Try a pair of vice grips. Squeeze them TIGHT.
Not a large enough screw head, I think it's gonna be a bolt removal tool. I don't want to cut the nets, but I don't want them on anymore.
daberry
68
Kansas
My dealer never installed them.
bigc
bigc
432
127
if you heat the bolts with a torch or propane bottle alittle bit the loctite will turn loose and they should unscrew
jwilliams3
6
I picked up my 700-4 yesterday and tried to remove the bolts because it doesn't look like it was installed right. The netting was installed at the dealership friday and the bolts seemed to be overly tightened. I used a metric allen wrench and when it seemed like it was going to strip I stopped. Started to check to see if it was a star screw or regular allen. Has anyone successfully removed them?
Elkhunter
Elkhunter
345
453
Minnesota
Took mine out no problem. Yes they were tight. Make sure you use a metric Allen wrench
Clarky
108
I removed mine the other week. They were very difficult. They are 5mm. I initially used a regular L shaped allen wrench. This worked on some, and not on others. I almost stripped a few. So, I bought a set of Kobalt metric allen sockets from Lowes. I used my torque wrench, since it's nice and long. With that combo, they came out fairly easy.
I had to buy a nice set of Klein T Handle allen wrenches in metric and Standard. the 5mm worked but I ended up with a bent wrench! Suckers were in there TIGHT!
barefootwelder
11
I used my 1/4" Makita impact driver with an allen on it.
spifyd
spifyd
419
178
newhampshire
Mine had wounded out torx. A fresh par of vice grips go them started.
Also found many loose cage bolt.
spifyd
spifyd
419
178
newhampshire
A new pair of vice gripes will grab them. New being the key word.
Theron
Theron
50
30
Anchorage Alaska
+1 dewalt impact drill.
They all came out with some effort. I think a couple didn't have room to get the impact on them but they came with a regular metric allen. Heat would help but be carefull with the paint.
The funny thing is that for as hard as they were to get out, one u bracket fell off completely on the trailer. About 20 miles out of the dealer I noticed a net was flopping around a lot and wanted to check my straps anyway so I pulled over and a whole bracket was gone, after a little search it was just caught under the tire, but of coarse the bolts were gone. I figure they must have forgot to torque that bracket and may have only hand tightened it. It was months later when I removed the net and was surprised how hard the bolts were to remove after having two fall out when it was brand new. Once you break them loose they come easy.
W
wvrider
14
Yes they are tight I used a star bit and took one screw out this is were I mounted a 5 inch round mirror on one of those screws worked great.
E
Eeluk
12
I need to buy a window net anchor fitting that goes on the windshield pillar. Cannot find them anywhere on the web. Anyone here want to sell one?
USMCsilver
USMCsilver
109
147
US
I used a Dewalt 24v impact wrench. Came out fine with some noisy encouragment.
Sent from my SM-G935V using Tapatalk
Reactions: CumminsPusher
jinx
jinx
565
528
3/8 drive 5mm Allen bit socket on a long ratchet took mine out easy
