sandbaja
I purchased a new ride that had 4 miles on it. When delivered the I4wd light came on but cleared after a short >20mph drive. Initially, I suspected a ghost fault but it reappeared several times over the next week just driving (gently) around the neighborhood. This is my second Talon, the other a 4-seater LV has never had an issue. So, before I took it on the trail, I took it back to the dealer for resolution.
The dealer applied a code reader ( I assume it was the Honda tool) and found 2 brake faults and two i4wd (DTC 61) faults. Since they both revolve around the 4WD module, the modulator on the surface makes sense. They cleared and retested, and the DTC returned. They ordered a I4wd modulator which should be replaced tomorrow. This aligns with the service manual yet I'm not comfortable assuming this is the resolution. Hopefully, I am just being paranoid. I did do a cursory check of grounds and connections before taking it in and also considered the issue was created during the steering wheel mounting at PDI.
