Thanks to HondaSxS good buy works great.
sporttrac4x4 Well-Known Member Lifetime Member Jan 7, 2016 1,177 2,082 113 ILL. Ownership Other Brand Mar 1, 2020 #1 Thanks to HondaSxS good buy works great. Last edited: Mar 1, 2020 Reactions: JenElio, JimmyA, Russ989 and 2 others
Admin HondaSxS.com Advertisment Rhino-F350 Member Jun 28, 2019 34 41 18 59 Wisconsin Ownership 1000-3 Mar 2, 2020 #2 How was installation? I recently bought this kit have not installed yet. Thanks in advance sporttrac4x4 Well-Known Member Lifetime Member Jan 7, 2016 1,177 2,082 113 ILL. Ownership Other Brand Mar 2, 2020 #3 Easy install just find the wire above the oil filter remove plug thats in the end of the wire. plug in wire run wires To the light where you put it. Russ989 Land of the free because of the Brave! 🇺🇸 Lifetime Member Supporting Member Club Contributor Dec 18, 2017 22,588 146,743 113 Missouri Ownership 1000-5 Mar 2, 2020 #4 Rhino-F350 said: How was installation? I recently bought this kit have not installed yet. Thanks in advance Click to expand... Reactions: Lapcinski, sharp and Rhino-F350 Russ989 Land of the free because of the Brave! 🇺🇸 Lifetime Member Supporting Member Club Contributor Dec 18, 2017 22,588 146,743 113 Missouri Ownership 1000-5 Mar 2, 2020 #5 I started out with the single and then upgraded to the dual kit. The work light trigger switch is a nice addition as well. @Hondasxs makes some good items for sure! Reactions: Mudwing, Rhino-F350 and CumminsPusher Rhino-F350 Member Jun 28, 2019 34 41 18 59 Wisconsin Ownership 1000-3 Mar 3, 2020 #6 😎👍🤜 S Superthrill Well-Known Member Supporting Member Oct 4, 2018 667 1,557 93 North Carolina Ownership 1000-5 Mar 3, 2020 #7 I did the dual as well. I wish i had added the work light switch! They are great lights and easy to install! Reactions: Russ989 JimmyA Well-Known Member Oct 8, 2017 1,644 5,504 113 Northeast texas Ownership 700-4 Mar 3, 2020 #8 I put the same kit in mine! Reactions: Russ989
